Recently my check engine light has come on with a fault code 31, wastegate solenoid signal. Now I haven't been using the solenoid to control boost since I bought the car. I have had a manual inline boost controller. I have left the solenoid electrically plugged in and blocked off the vacuum lines. Why all the sudden would I be getting this fault? If the solenoid itself is bad, is there a way I can make the ECM not want to see the signal coming from the solenoid since I'm not using it?
Quick rundown of my setup, 009s, gt3255e w/ THDP, stock MAF, RJC power plate, Erson 208 cam, otherwise stock engine.
Any help is appreciated.
