SignUp Now!Iam planning on buying an fbody radiator, do I need the dual fans? I do not have a FMIC, will the stock fan cool it just fine? If and when I get a FMIC then I would buy the duals.
The only reason I would not get the dual fan setup is my money is tight right now, and Iam a bit weary on buying the fans and having them crap out in a year or two. Plus it's not that hard to change fans
Did you check the connection at the relays?...the dried out dielectric grease clogging all the sockets and coating the pins and killing the connection? My fan was spinning at maybe 500rpm when I got my car. It was overheating all the time. After cleaning all that crap out at the relays and making it a solid, clean connection, my fan spun like a champ. Did you also burp the system when you swapped radiators? Theres no reason for your engine to run that hot even with a fan crapping out. I can drive 33 miles all the way home without my fan even turning on. Its set to turn on at 175, and it never gets there.If your stock fan is performing properly, you will not need dual fans. Install the new radiator and watch your temps, then go from there.
FWIW, I was having mild cooling issues (temps would creep up over 220 hot day in FL with AC on). I put in the Fbody radiator and it helped some, but the real problem was that my stock fan was crapping out slowly.
waddell87- whats with the hostility?
If you think Florida has bad traffic, then I invite you to southern california. The fans do come on, but it doesnt go above 180 in summer traffic. In the cooler seasons, I can sit in traffic with it never going above 168 and the fan never coming on. If the gap between the shroud and the radiator is too big, then the fans are absolutely doing you no good. They arent moving any air through the fins.I'm certain the stocker was on it's last leg. We're talking over 175k miles. When I bought the dual fans, I took the stocker out to test fit the new fans. I set the stock fan flat on the bench. When I re-installed, it would no longer work at all. The "test-fit" day turned into a "need to install now day". The duals kept temps down usung the factory relays untouched.
BTW, If your temp stays below 175 on a 95 degree day in FL standing in traffic with AC on high with no fans, then you have access to some miracle technology.
Mine works fine with the factory fan however I do not live in Florida. During July and August we had 98 degree days and my temps never went over 194 and yes that is town driving. On the highway it drops to 180's.
If you mount the shroud on the inner side of the mounting brackets instead of the outside, the gap will be just about right. If you have no gap, then the fans have to work really hard and have a hard time maintaining rpm, and thereby dont have enough flow to pull air through the fins. At least thats what I found. I tried no gap and the temps shot up about 20 degrees all around. With the shroud mounted on the outside of the brackets like stock, it ran about 10 degrees hotter than with it mounted on the inner side.I was thinking the same thing putting an F Body Radiator in my TR. Arent they Aluminum? What year F body fits TR's? Will it leave too much of a gap?
Jason
