Felpro 1200 gaskets???
JeremysGN
Match ported my intake & had a good port job done on my heads. I want to use the 1200's but what are you suppost to do about the valley?? I've got about 1/8" between the bottom of the intake and the block valley where the pan would usually seal. This will get pressurized under boost won't it, and I figure it will just blow RTV out?? What do you guys run here. THANKS Jeremy
