felpro install
gmturbo
Northern Turbo
I purchased a felpro unit for a V6 turbo engine. I'm having
trouble figuring out the interface set-up. I have the harness
the goes between the stock harness and felpro unit itself.
also I have been supplied another I can't make heads or tails
off. How do i plug in the wide band 02 sensor to the existing
stock harness. If anyone can help I would greatly aprreciate it.
I'm really confused on the install....if anyone has a step by step
explanation.
i bought mine from terry ryan and it came with the interface harness that you ran from the stoc location to under the seat and then another that you had to route to the front of the car it had the power pos wire then 3 grounds and a bunch of others in a bundle 7 wires if i rembember right and a fuel inj wire the 7 wires were for the wide band o2 but did not have a plug on it the plug also came as a pigtail that once you ran the wires you had to connect it to the other seven wires
hope this helps
shawn
You have to run the new wb O2 "harness" seperately, then that plugs into the adapter harness if memory serves. The wb O2 harness should have been included with your adapter harness.
TurboTR
