So my headgasket blew out and since my car has been down i am trying to see where i want to go with it. Always looking for input so please speak up if you have a comment to make.
1.)Alky Kit
2.)Bigger injectors
3.)Rear Sway bar http://www.hrpartsandstuff.com
Getting the headgasket fixed so if anything can be done thats not to expensive while this is getting fixed i might as well square it away also. I think i can have about 3k to spend to get everything done. Even if someone has some input on beefing somehting up on the car as in trans,susp ets etc i would like to hear your inputs.
Car info
Nothing special really its a weekend driver if that, not looking to be the fastest but i don't car to be the slowest either if you get my drift.
Transmission upgrade was done by Phoenix transmission.
There was a cam added, I believe .010 over pistons
TE 44 turbo
Precision front mount IC (stock location 21 row was added when new engine was put in
Replaced the engine w/ a crate ATK 109 long block.
High performance fuel pump & hot wire kit
Chip was custom made by “TurboTweak”
Car is equipped w/ TE 44 turbo,
21 row stock location intercooler
2800 Stall converter
All pluming is 3”
TRIAL Waste gate
K& N air filter
42.5 injectors
2.5 mm plug wires.
Headers
1.)Alky Kit
2.)Bigger injectors
Car info
TE 44 turbo
All pluming is 3”
TRIAL Waste gate
K& N air filter
42.5 injectors
2.5 mm plug wires.
Headers
