kingots2004
- Nov 6, 2007
1. What type of ignition system does your car run- where is the crank
angle sensor (CAS) or distributor trigger wheel and what type is it
(Optical/LED Sensor? Hall Sensor? VR Sensor?)
2. How many teeth/windows/slots and what orientation does the CAS,
crank
trigger, and/or distributor wheel have? (any missing? all evenly
spaced?)
3. Is there a distributor? Single/Multiple Coils? Coil on Plug?
4. Does this engine have a fast idle valve (IAC)? If so, how many wires
are connected to it? Do you know if it is an on/off, pulse width
modulated, thermal, or stepper type?
crank
spaced?)
