Few small things needed
jdpolzin
Maybe some of you guys that parted cars have these small oddball things?
2. Plug in the trunk for the trunk light with a short piece of the orange wire so I can splice it in.
5. Power trunk release mechanism
6. shifter cable
7. Under hood light
8. small chrome piece for the shifter handle. I need the one on the bottom that the shifter rod goes through (round one)
9. one aluminum color discs that would get glued to the radio button, or a radio button with the pieces on them already
6. shifter cable
7. Under hood light
Hey, should have the trunk light wire with the splice. I have a power trunk release mechanism. I have a shifter cable. Should have the lower chrome trim ring for the shifter. $40 plus shipping. Let me verify what I have and let me know Jeremy if your interested.
I got the trunk actuator do you need the harness wire that snaps into it?
Shifter cable is good just the Rubber boot is cracked. Cable works fine.
Also you just need the harness clip and some orange wire you have the trunk light is that right? Still looking for the chrome ring.
Thanks brother! I dont need the harness for the actuator, just the actuator. Yes, just need the plug and a short piece of the orange wire for the trunk light.
Jeremy, I think I have a complete radio ,I def have the buttons, I jus gotta find them. You need anything else from it?
Actually I just need one button that has the little aluminum disc. If I could find the time, I'd go run over to the junkyard and get most of these parts but time has not been available lately. Thanks for the help guys!
Jeremy I found the shifter trim piece. So I have that , Shifter cable, Trunk wire, and the trunk actuator.
Send me your address and I'll give you the shipping quote.
This pic is for Tricksixpa
