Fiber glass bumper filler fit question
BOP4ever
I test fit my new rear fillers and the overlap about 1/4 inch. Is this how you leave then or should I try and trim them for a flush fit?
Other wise they seem to fit pretty good.
Mine were trimmed for a flush fit and glassed together to make it one piece. :)
Oh does anyone know what size nut will thread on the rear studs ? Id like to get away from the stock stamped nuts....
I don't know what size the bolts are but the damn factory speed nuts destroyed all the threads. Now I have to try and replace the bolts. Should be fun.
Another reason I wanted to replace them.
Mine are buggered up some but I think a nut of the right thread pitch will straighten them up... hoping...
Where did you get them? Most dont fit 100% & need some work.
G-body parts.
THe only gripe I have is the bolting flange needed to be longer I ended up with slots one top on one side, but after putting the tail lights in they are tight against them. I have the bumper off but held it up and it looks like it all will fit nicely.
I guess I can use my cut off wheel and grind cut them flush and hope I don't end up with a gap.
