Fiberglass 2" cowl hood
monkeyy337
Looking for a 2"-2 1/2" fiberglass bolt on cowl hood for a 1984 Regal. The hood must have the capability to use the front latch system and have no holes drilled/cut for hood pins. The hood must also be within 100 miles from Bowling Green, Ky.
OK, I will travel 150 miles if you got a hood. I've got a steel cowl hood on the car now and need to loose some front end weight.
