First pass on new motor
grey racer
livin the dream
Pump gas....22psi.....launched on 3 psi..... 17 lbs tire pressure....26lbs pass side air bag, 12 lbs driver side.....
1.54 60ft
4.35 330ft
6.74 1/8
1/8mph 102
8.82 1000ft
1/4 10.54 @129mph
Sig tells it all........:D:D:D........................thanks Cal.
Nice run! Car sounds great, what exhaust are you running?
Bryan
Bryan
The exhaust system was on the car when I bought it and the muffs have no markings on them....
and most of what you hear on the vid is the corvette in the other lane cause he was always closer to the camera...if you know what I mean...!
Impressive. Alumium heads?
Champion irons... in the process of installing 9.5 in. 3200 non lock vigilante.... should improve things a bit....also considering alradco alum radiator depending on
how the temps look with the non lock....... does it ever end ??????
