- Aug 1, 2003
you missed it ...Maybe I missed it, but do you have braided brake lines? It's an $80 generic G body kit from Jegs...between the braided lines and S10 wheel cylinders, I can build some decent boost! Made a HUGE difference off the line
hes trying to install a line lock and what he has trouble finding is a line to hook the master cylinder to the line lock so that its bolt in and go without cutting the stock steel line ...line locks arent to hold the brakes at the line they are to heat the tires up in the burnout and not heat the brakes up in the process.
sticky tires will hold more at line before they spin , if you push and the fronts are rolling you may find doing the front rubber brake lines helps , if you're sliding the fronts the backs brakes need more work
if the s10 cylinders /shoes and good bleeding/flushing with fresh fluid dont hold for him i agree the old rubber line at the axle should be replaced and the russel kit (listed as for monte carlos with 7.5 rear) fits and includes the rear line at axle to frame and the front lines to the calipers , kirbanperformance.com carries the kit as well
on the quick ..no extra parts ..the ebrake launch can work too (pushed withing reason)
