Nov 20, 2010 #1 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,210 Can I uses a SST flash eeprom 27sf256 instead of the 27c256 chip in the caspers 8 postiion thumbwheel?
Nov 20, 2010 #2 G GNandGS I'm still here! Joined May 24, 2001 Messages 2,733 I take it you have both? If its just laying about see if you can load the data you want... if check sum ok then proceed?
Nov 20, 2010 #3 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,210 I dont have the flash chip but was thinking of getting one instead of UV erasing each time.
Nov 20, 2010 #4 G GNandGS I'm still here! Joined May 24, 2001 Messages 2,733 Until an expert chimes in I'm gonna keep guessing. If the only diff is in how the data is cleared but the pinouts, data addresses, etc are the same then I cant see why it wouldnt. If cheap and easy to get I would try! But thats just me.
