Blown&Injected
- May 31, 2001
Battery was not charging, no power to the exciter wire, volt light is out. The sudden drop in volts cause a lean out and nasty KNOCK
but I digress...
It looks like the metal contacts on the bulb fixture has worn out the contacts in the plastic flexible circuit board. I do not even know what this thing is called to even ask if it is available.
Broke the speedometer (VSS) digging in to all this - What a mess.
Was thinking about just using some very small wire to hard wire the bulbs to the plug the board makes contact with unless this thing can still be had.
Also wondering how much a speedometer costs or is it called the VSS? It looks like the entire "speedo" assembly is ala carte not just an entire unit.
