Sorry for the confusion, been a while since I've posted, read the first post in this thread. Now after that I pulled the engine back out stripped everything off to a bare block. re-ringed the pistons, new head gaskets, arp head studs, new intake gasket, and threw those ebay injectors as far as I could across the shop! I got a set of blue ring 42.5# injectors from gbody, and put engine back togather. Before installing engine I broke down the entire engine wiring harness, soldering and heat shrinking any and every break cut or nick in wiring at the time I found when I spliced my own C3I plug I had the crank sensor and cam sensor wires crossed to the module, corrected that and loomed all wiring. Installed engine, was told since I'm using an 87 ign mod, coil, ecm w/ tt chip I have to use an 87 MAF sensor... Only code I'm getting is for the MAF, but I have not driven the car. Only started it, at least this time the oil pan is not filling with fuel and is not blowing raw gas out of the tail pipe, so I must be getting close
