so i finally got around to getting my GN up here to MD from VA, it had been at my buddys house down there with a cover on till i was able to bring it up. So the next morning i look over to the rear of the car on the passenger side and noticed the carpet was drenched with water so i took couple of towels dried it off best i could being that it was in the 30s, i pulled the carpet at the back of the vehicle and didnt see anything major just some surface rust and some bubbling of the factory coating.
Today i got around the removing both seats, center console and pulled out the carper along with the padding, again nothing too bad from the initial look. I took my wire wheel and drill and started going at all the spots that had rust, a couple of which had some good size pitting and 2 very small pin holes which appear to go through, they were real small to where i couldn't even fit .032 safety wire through. Now i have a lot of bare metal spots, some with pits some with out, any recommendations as far as protection? I been looking online and leaning towards a product called Miracle Paint, seems easy to use and dries rock hard. Also for the areas with the pitting and the fine pin holes, what can i use to fill them in? I saw one video where the guy recommends using the Miracle Paint and impregnating fiber glass to use on non-structural areas of a car, and he used the floor boards as an example.
I will be leaving the padding and carpet off till i find exactly where the water is coming from but i would like to get the areas of bare metal treated asap, right now i just applied some amlguard i got from my job to keep the bare metal spots from starting to rust.
