Hello,
New member here, and first time poster. I've checked many of the discussions on here, but have not found what I need. I've been building cars for over 20 years, but never a Turbo 6 cylinder. I've recently purchased a 1984 Hot Air T-Type, WH1, T-Tops with only 41k on the odometer. The plan is to make a cruising show car, but I want to modify the engine to give me upwards of 500 HP, just because. The engine has a couple oil leaks from sitting, rear intake and valve covers, I already changed the valve cover gaskets (what a joy on the passenger side) so I decided I will just pull the engine to do the intake, and refresh the engine, and engine bay at the same time. Here is my dilemma, I'm not a "pure stock" kind of guy, so I'm torn between building the hot air up to 500 hp, or just dropping a V8 in, but I just can't bring myself to that (just yet). Question: Is there a "menu" of parts and work needed to bring a H-A model up to approximately 500 hp, im sure it's been done, so I'm looking for a little guidance. I'm not against dropping in a modified HA T6cyl, if there is one for sale, already built, so any help is appreciated. Thank you.
