Florida 1986 Buick Grand National
tbirdv6
1986 Buick Grand National, Hardtop ,w/35k+miles
Interior:
A/C, Power Windows, Cruise Control, Tilt Wheel, Push Button Trunk, Factory Trunk Kit, 1990 Regal GS Leather Seats (pillow top)gray in color that tastefully fits in & all electric. No Rips,Holes, or Tears in any of the interior or missing parts
LapTop w/stand, Power Logger,Maft Pro w/adjustable boost,Innovative Wide Band, Scan Master, Audible/Lighted Knock Gauge, 2 Pod Pillar Gauge has Boost & Wide Band,Has unique 3 gauge interior matching pod (fuel pressure, water temp, & oil pressure)
JVC 4 Channel AM/FM CD Player w/new front speakers & rear 3-way 6x9’s
Remote Alarm ,w/GPS Security(reports to 3 phone#’s w/location for continuous tracking)
Raised Arm Rest (double compartment), engraved shifter handle,inlaid console w/3 rocker switches (has electric cut-out for dump pipe,low/high cooling fan,lock-up converter)
Mark Huff’s inserts on exterior door handles,door pull straps
Rear Seat Frame Braces
Chrome Halibrand Cobra III 17” Wheels (the real deal)
Tires, Front ,245/45/R17 Fuzion ZR1
Rear,275/40/17 Fuzion ZR1
Bilstein Shocks & Eibach at all 4 corners
Rear Air Bags
Front Tubular Lower Control Arms
UMI Upper/Lower Tubular Control Arms
Rear ATR Sway Bar
Pinion Snubber
Driveshaft Safety Loop
SSCB Dual Piston Front Calipers
All Poly Graphite Bushings
Under the Hood Braces
Engine
.30 over
Balanced w/K1 Rods & JE Pistons
212/212 cam w/HD Rock Arm Assembly
Port Matched Intake
Ported Heads w/Bigger Valves
All ARP Hardware
3 ½ Terry Houston DP w/electric cut-out dump pipe
Atr Exhaust
Alky Control Methanol Kit
Precision 67 Turbo (4”in, 3”out)
60 lb Injectors
70mm Throttle body
RJC Front Mount
RJC Billet Pulleys
Speed Density w/Cold Air Induction (no reducers)
Dual Ramcharger Fan w/Racetronix Harness & 4 core radiator
Caspers Grounding Kit
Racetronix Injector & Hot Wire Fuel Harness
Walbro 340 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
Lifetime Power Master w/new Proportioning Valve
Under Hood Kirban Chrome
Driveline:
CK 200r4 Transmission
9x11 3400 Stall Converter
3” Drive Shaft
Eaton 3.42 Posi
Art Carr Deep Tranny Pan
18k or best offer
Located in Tampa, Fl
Email for more info & phone #
turbobuick4@yahoo.com
more pics
more pics
What is the mileage on the car? Do you have any info on the history of the car? Thanks
Steve
Will consider Partial trade + Cash
Looking for a decent daily driver w/ac & paint
Will consider partial trade + caSH
