the actual muffler case that Flowmaster uses in the GN kits is the very same one they use in all the crossflow Camaro/Firebird/Nova kits out there, but with 2.225 adapters welded to the 3" inlets instead of the 2.5" adapters that are welded on for the Camaro kits. the 80 series is essentially a pair of 40 sereis mufflers welded end to end, and a 40 series is capable of supporting a butt load of power.
when it comes to airflow for a given power level, the same amount of air is gonna go into and out of a car whether you have 6 or 8 cylinders with a single carb, dual carbs, efi, an 8-71 blower, a paxton blower, or a turbo or two hanging on the motor, so if a muffler is good for 500hp on a single carb application, it's good for 500hp on a turbo application. especially if it's mounted farther back from the engine.
i had the F body crossflow setup on my 71 Nova with close to 400hp, and it sounded wicked and the motor was snappy and pulled hard to 7000 rpm's, so i don't think there was too much restriction going on there.
i have the Flowmaster GN kit on my 84 T, and it sounds like a stocker with a little bit of a "twang" when it gets up in the rpm's on boost. but i don't think it's a restriction at my power level (not much above stock). in fact, it's actually a bit snappier and quicker according to my butt dyno with the Flowmaster setup on it than it was when i got it with no muffler back there.
if i ever do step up and make some serious power, i'll probably get a 2.5" or 3" exhaust setup made and use the same muffler, since i've already got it and it's fun when people look under the car and think i don't have a muffler at all...
