Fluid
Razor
Forum tech Advisor
Staff member
Well here's a sticky/messy question.
In motor oils I feel theres a huge difference as to the quality of the oil.
Does this hold true as far as Dextron ATF fluid,or are all dextron fluids the same?
If not...what is the best non-synthetic fluid?
And is Type F recommended to be mixed with dextron?
Thanks guys,doing my shift kit/transbrake tomorrow nite.
I've always heard to stick with the Dextron II oil in the 200r4 trans.
Not mix the oils either.
HTH. JS
Thanks JS...Its funny no one replies to this.
Is walmart .80 cent atf the same as 1.79 valvoline atf?
I agree with you on the no mix.I prefer a softer 1-2 and the dextron should provide a slight allevement..
I'm playing tranny man sat am.
I don't know. I would just look at the manufacturer lable on the back to identify it.
Stick with the one you trust.
I feel your pain:( too many times
