FOR SALE - "Category 6" -
tweaked2
FOR SALE – 1987 BUICK Grand National – “Twin-Turbo GN Race Car & TRAILER”
“CATEGORY 6”
“Category 6” puts out well over 1000HP in social mode and runs “EASY” (5.20’s 1/8M) 8.20’s @ 165+ @ low boost and w/o using Lock-Up converter … (on bad track).
VERY peppy in social trim (20# – 24# boost). Mid-to-high seven’s second performance easily attainable … with just a little “tweaking”.
EVERYTHING IS NEW! - Less than 20 runs on motor, trans & drivetrain.
A TRUE back-half w/stock fire wall, stock A-Frames and all in the stock location. Weighs in at ~~ 3000# w/driver.
Engine and Components: 265CI, 4.1 Stage 2, On-Center block, 3.500” Forged steel crank, Forged Pistons, Steel 6.5” Rods, Dry sump oiling - pan, reservoir & multi-stage pump, mechanical roller cam & lifters, Stage II aluminum heads (ported/polished, BIG - Titanium int./exh. Valves, T&D roller rockers, Stage II valve covers, CPP Custom Sheetmetal Intake, 90mm throttle body, HP front timing cover, MSD distributor, crank trigger, MSD 7AL2 ignition, MSD 2-step, FAST sequential system w/wideband O2. FAST datalogger, 160#/hr fuel injectors, Weldon HP fuel pump & fuel pressure regulator, Custom HP aluminum radiator. Hi-volumn electric fan, MSD HP plug wires.
Turbos & Intercooler – TWO[2] Limit Engineering T-63 turbos, SS Headers, Dual wastegates, Custom air to air intercooler, CPP boost control.
Transmissions - API Big Brute, 2-speed automatic w/LU converter, SFI HD case, Electronic shift & LU, Carbon-fiber driveshaft w/MW ends, Electronic shift controller.
Chassis/Accessories: Certified Chrome-moly roll cage, 4-link with NEW rear anti roll bar, coil overs, current certification, Ford 9 inch rear end, 35 spline axle with spool (4.88 gears), disc brakes – front, Fiberglass hood, bumpers, doors, rear decklid, Lexan front, rear and side windows, Flaming River Manual steering rack, fuel cell, Rear mount battery, New battery, Parachute mount with chute, Custom gage cluster w/Autometer gages & Tach, Rear battery cutoff switch, wheelie bars, rear spoiler, KIRKY seats, NEW Hoosier 33” x 15” slicks & front runners. CUSTOM Black-Cherry Pearl paint w/gold metallic flake and custom “Category 6” graphics.
FEATHERLITE 24’ Tag Trailer: Interior paneled w/overhead lights, Front cabinets.
Conley’s Performance Plus INC. constructed “Category 6” for a very good friend and customer who now has business opportunities that necessitate the sale.
His opportunity … is your gain! THIS CAR NEEDS NOTHING!
Car & Trailer PRICED for quick sale - $59,000 OBO
Call Chris @ 281-540-FAST for pics and poop.
conley@wt.net
Check out www.conleyracing.com for pics.
