FOR SALE...engine mount, injectors, timing chain
Way2QWK
Turbo Spooled by CORN
Have a few things to get rid of.
1. Used fuel injectors. Ford EV14 with adapters for Buick harness. These have about 2,000 miles on them using e85 fuel mostly. These were on a running Buick that I purchased but removed them to run a different size with a new motor. The chip was from turbo tweek and burned as 80lb injectors. As I understand these are stock Ford injectors modified to flow as 80lb. Full part numbers are scratched off by the company that modifies them. Fomoco B556v. Thats all I know about them
Asking $50 plus shipping
2. TA performance stock style timing chain set. TAV155b.
Used set from same engine as injectors above. Around 2k miles. Removed because I prefer using double roller chains with no tensioners. New this set is $115
Asking $55 plus shipping.
3 GM left side motor mount.
Im pretty sure this is a new remanufactured mount from GM since it appears new but the metal has installation marks. Have had this in a box for probably 20 yrs or so.
SOLD>>>>>>>>>>>>>
