C
coach
Guest
Is it possible to put a 9" under our cars that is narrowed an inch per side and still have the G-Body brackets in the correct mounting locations? I found some rims I want to use, but they are 15x10 and the backspacing is about 3 3/4. I figure I need at least 4.5" or a little more, so I need to narrow the rear at least 3/4" per side, to tuck the tires in correctly. I also know that the shock/ trailing arm mount is already pretty close to the backing plate. Has anyone done this?
Future project in the works...
Coach
Coach
