A couple of questions regarding the ford rear axle. I think I understand why most convert. One has to do with the sheer availability of the parts. This coupled with what I believe to be strength makes this a nice swap.
The axle housings have those brackets that the axles backing plates bolt to. Is that backing plate a part of the bearing assembly, I am trying to get my head around how the whole assembly works.
Additionally the length of the axle, if you go with a Ford do they make one the same length as the Buick? Then there is the question of the axle and the bolt pattern. You will obviously have to use a ford axle so that means a different bolt pattern or is the pattern the same between GM and Ford?
I am debating a 9" rear but, I am trying to get my head around what all will be required. I notice some simply cut the ends off and use Ford Ends. Then what type of axle do you use can you use a Buick axle and then Ford bearing and backing plate?
I am completely lost without a diagram.
