Anyone using the 9 inch in their GN and have upgraded to large rear wheel cylinders? I have been trying to locate some large cylinders ? Maybe you remember the application.
Got a Ford 9" in my GN and if yours has the 11" drum brakes you should be all set. The wheel cylinders are already bigger than the ones on the 8.5" GM rear.
Agreed. Be careful driving on wet pavemnt with that combo. If someone were to use bigger cylinders it would lock even easier. Roger the Dana 60 is heavier, not as easy to change gears, and is more expensive when performing the same maintenance as on a 9".
