Ford houseing & axles,weld wheels/slicks F/S
turbolou
Lou's Automotive 949-378-1590
Ford 9" housing with back brace & brackets with axles. $600.00 Set of weld draglites with 4.5 x 15 M/T front runners & 12/28/15 Goodyear's.$600.00 Four passes on tires, These parts came off my TT V/8 regal Which was recently back halved by present owner. Local sale preferred, Pictures on request, 949-378-1590 for more info. Lou
Lou, would you consider separating the rims? I'm interested in the fronts. Also, are they 15 X 3.5 or ??
Thanks, Scott
p.s. I'm in Vegas, so pick up or meet would be fine.
Who's housing and axles?
Reply!
Thanks, Scott
Scott I will be dropping them off at Lens shop. He has spoken for the rears & if he doesnt want the fronts I guess something can be worked out. Speak to Len about that. One of the front rims has some run out & will need to be replaced. Tires are as new. I'm not sure on the rim width but 3.5 sounds about right?
Reply
The houseing & 35 splined axles are Curry's it's for a G-body car back brace rienforced & with wheelie bar brackets. Professional quality pieces. I would rate it to stand up to 1'500 H.P. with no problem.
Lou,
Does the housing come with Ford ends? Maybe I could stop by and take some measurements. I was about to pull my differential out to change the gears.
Jeff
reply
Jeff Rand said:
Lou,
Jeff
Yes it comes with the ford ends. That way you could use alot bigger brakes also.
