If you don't mind cutting half the front end off of your car, go ahead and do it. My car is already a POS and I'm still feeling guilty for hacking it up this much. I thought it was going to be a little grinding but I have to start with the big 1/2 hp grinder. The place I have to grind on the core support is double walled and a regular dremel or die grinder would take a few months to cut through it all. It's tempting at this point to make a pipe to connect the turbo to the TB and run it. It looks like the amount of hacking that needs to be done was left out in other posts about this IC. I'm hoping I don't have to move the battery to the trunk to clear the hoses.
