- Jan 21, 2007
…all parts you pay the ride. Thanks
Stock turbo 42000 miles no issues $200
Turbo Shield $85
ECM with power logger. Works great only removed for GNECU could use one screw. $210.
NOS Front Bumper Filler. $75
NOS Shifter handle. $25
Used GM Radiator hoses $20
Crankshaft Harmonic Balancer Bolt $15
Flex Plate $65
Fuel Rail and Lines. Rail has small sent on top. $130
Fuel pressure Gauge. Fits on end of Rail. $15
Inlet Bell $5 Cleaned the rock tumbled.
Thermostat outlet Tubes. Stainless $10 Stock $20.
IAC ASM $50
Knock Sensor $10
Oil return Block Fitting $25
EGR Control Valve Sensor $70
Oil Cooler Adapter $40 and $20
Valve Cover Breathers $10
Intake Cooler Pipe $45
Coil Pack Mounting Bracket $25
Coil Pack Support Bracket $23
Alternator Bracket powder coated $55
Thermostats retainer powder coated $10
Intercooler Fan $50
Pick a part last PIC $10
Turbo Shield $85
Flex Plate $65
IAC ASM $50
Knock Sensor $10
Intercooler Fan $50
