Guys,
- My tranny guy pulled my old 200-4R trans apart last week, and has a question about the forward apply ring. The trans had a Pro-Built modified TransGo kit, and worked fine; the 1-2 accumulator spring was broken when I got the trans, and there were rumors that the car it was in before was a demo derby car. It did seem to work fine after I installed the kit. IIRC, it was a stock '82 trans.
- I drove it hard probably six months prior to failure. The trans failed on a hard 1-2 upshift at 6200rpm behind a ~350HP engine; BANG, then nothing.
- The problem is that the forward apply ring is mashed where the ends come together. I'm not dumb enough to do neutral drops, and I don't know what else could have caused this. The trans was used when I got it, and not disassembled until last week.
- Is this probably a prior condition? If not, what else could have mashed the apply ring? Is this unusual, and would it be worthwhile to have my machinist buddy cut a new solid ring on the lathe?
- Any advice would be greatly appreciated.
Thanks,
-Glen
Thanks,
-Glen
