Well I finaly tore into the motor and found some things I didnt like.
First when I pulled the heads off number 3 cylinder h/g was u shaped and it looks like 2 & 4 have been leaking.
Then I pulled the front cover off to find the timing chain tensoner(spelling) was broke into three pieces and the plastic piece was in about 100 pieces.
Then pulled the pan and found the spring and the rest of the tensoner. The oil pick up had a bunch of stuff stuck in it.
Pulled the main caps loose to find the thrust bearing was messed up bad. Guess that would explain the in and out play in the crank. The thrust bearing was gone far enough to let the crank rub the main cap.
Soooo on to the questions.
1. Sence I am going to have to replace the crank do I go with the billit stock replacement or the stroker?
2. How much difference is there in the two in respects to building power.
3. Is it worth it for a daily driver.
4. what is a good roller cam that has a chopy idle to it.
The car is a tta and I would like to get into the middle 10's with the build
