Guess I have a fault that is broken...
At last I got my hands on a compression tester that fit the heads, well almost. Had to make some minor adjustments. So, to the test...
All cylinders where 9.5kg... except one... thought I had adjusted the tester too much, because how I tried, I couldn´t get any readings on cyl# 3... JESICA!!! COME HERE AND GIVE ME A HAND!!!
While Jesica turned the key, I put my finger over the hole... No pressure at all... So I put my finger over one of the other, and my god what a difference
Well, at least I´ve found where the problem is.
