chris kirk
- Jun 1, 2013
Let me clarify something so there's no confusion.Thanks, I guess I can still do that. It’s not like you be able to see it anyways right. I mean I’ll damage the powder coat but I rather be safe. How thick is the plate?
I my post/picture I was pointing out what Mike was saying about reinforcing the the shock/strut mount. I agree that it can be ripped out with continuous hard launches. And, if the frame is off then definitely reinforce them. In that picture I hadn't done it yet.
The tubular bars that you see welded in place were there to help keep the back of the frame from twisting under hard launch. Unfortunately, I had to remove them because I have an air ride/suspension and as a result was unable to fully lower the car with them in place.
The plates I had welded on covering the top of the spring mounts were done so if/when I wanted to put in a roll bar/cage. Will make it easier to mount an a flat piece of steel.
Sorry for any confusion....
