Frame Side Motor Mounts
WE2Regal
Looking for the motor mounts that bolt directly to the frame for a 3.8 turbo Regal. Pics of condition required if not local. Thanks.
You can get those at autozone or advance auto parts......about 18$ a piece.
Autozone said they only sell the mounts that bolt to the engine block, not the frame mounts.
If you are talking about solid mounts? ones with no rubber? If so you do NOT want those as they will run you out of the car. better off with rubber mounts with a strap....
Correct me if I'm wrong. Their are 4 seperate engine mounts. 2 that bolt on each side of the engine block with rubber isolators and 2 more bolted to the frame. The engine block mounts slide down over the frame mounts and a long bolt goes through them. I think you guys are thinking their are only 2. Look down the passenger side of your engine. You can see them there.
