If you want them, come get them. All of the fuel and brake lines from my 86 T-type. They are very dirty, but solid, no rust. If no one wants them they are going in the dumpster.
I can use what you do have. Its going to be a week or two before Im over your way again. If you need them gone quicker Ill try to get some one to pick them up.
Thanks.
Thanks.
You want the prop to master cylinder lines, or everything? I can hang on to the prop valve to master cylinder lines as long as you need, they aren't taking up any space. The lines along the frame take up too much space.
I mostly need the prop to master and the fuel feed line Ill check with the wife to see when we are going to be over that way I know its soon just dont know how soon.
