Hello ALL,
I just recently bought my first Turbo T/A.
It will make a nice project car, wanted something not so common down here in in Miami, FL. and keep it American muscle.
This car will be a streetable mph car. Not planning to do much 'out of the hole' racing. I took a nice long read through this forum to familiarize myself and have been cooking ideas up in my head
The TTA I bought is bone stock, 1 owner, 72,600 original weekend driven, never raced miles. Tranny has slight, slow leak, have not investigated the issue. Shifts fine, not really worried about it yet. Car interior is superb.
Please give any opinions and feedback on any mods I listed below.. as you all know the car pretty well. Many are running very different combinations, and everyone seems very helpful
At least mid 11 sec is target track time.
Please feel free to share any info on the sections below. Sorry for the length.
Block, heads, intake:
Would like to run stock block, Can and will work on heads sooner or later. Any recommendations on what to do to stock heads?
Larger TB and portmatch upper plenum is being considered.
I would assume lower plenum porting, etc. will be done along with head porting, cam work, etc. would like to know more of my options here. Nothing too radical.
I hear about the LT1 MAF.. is anyone selling the conversion online?
Fuel, electronics, turbo/DP, IC, exhaust:
Doing the standard stuff; Fuel Pump, Regulator, K&N filter.
The Alky kit sounds very interesting.
When upgrading the fuel pump/ regulator, which are the proven brands?
Turbo will be swapped not sure for which size. any comment?
What are the stock injector lbs?
would like to upgrade to higher flowing injectors, fuel rail, etc. when the turbo decision is made.
THDP 3" seems to be a crowd fav, apparently some fit issues with that..
Not sure what fuel management system to go with or what chip options I have... Seen several on the net, just dont know what is proven or what is junk. Any Input would help.
IC:
Liquid or Front mount? that is the question.
I heard 'Charged Air' made a front mount for the TTA, cant find them online.
Exh.
I would like 3" exh. throughout.. Any recommended brand. Would like something that fits nice. I like quality here.
Suspension Mods:
(stock suspension seems older and worn, need more control at high speed)
Please shed any light on where to start her if you own a TTA with suspension mods (street or track)
Brakes:
(stock brake are so so, need more) I was thinking New brake system all around - Rotors, calipers, braded lines, etc.
Maybe there is a more inexpensive route that works well enough
Tranny mods:
Can someone clarify what the stock TTA tranny is?
Hoping there is a shift kit of some sort that beefs up stock tranny... If not, any insight as to what the most common tranny mods are?
Thinking of some 18" CCW wheels with the mesh powder coated in the Gold color. 18x11 in the rear if i can make it fit. Will notch chassis if possible. any thoughts?
Ride height would need to be adjusted via Springs/Suspension for nice proportional look.
Pardon my ignorance, just absorbing the knowledge
I am sure I may have left some things out feel free to elaborate.
Thanks in advance,
AL
IC:
Exh.
Suspension Mods:
Brakes:
Tranny mods:
Thanks in advance,
AL
