From Mild To Wild!!!
Did you find those rear arms yet ?
Jimmy V wants them if you can find them... Either way... he or I will take them if you locate them. ;)
UPDATE
Bolt on Fiberglass cowl hood 4 ½ cowl $300.00
Stock Grand National hood with insulation mat on it (great shape) $300.00
Stock brake Powermaster with low miles (great shape) $250.00
95 lb/hr Injectors Precision Turbo 041-0950 Low $275.00
72 lb/hr Siemens low resistance Injectors 3145 $250.00
Autronic fuel management system w/software $750.00
Complete stock rack and pinion with power steering pump $ 150.00
2 Stock front brakes and pads $40.00
2 Stock front rotors $50.00
MSD dis-4 Ignition Box w/buick interface harness $200.00
Front stock sway bar $20.00
Stock heater core $ 25.00
Stock drive shaft $75.00
2 - 2 1/2 Inlet Pipes $40.00 Each
Stock Trans Crossmember 200-4r $80.00
