Bolt on Fiberglass cowl hood 4 ½ cowl $350.00
Stock Grand National hood with insulation mat on it (great shape) $350.00
Kenny Bell 70mm TB with upper dog house polished $300.00
Stock brake Powermaster with low miles (great shape) $275.00
Be Cool Radiator BCI-62018 Auto trans $525.00
Ramcharger Duel fan with plug $125.00
95 lb/hr Injectors Precision Turbo 041-0950 Low $300.00
Pin on Fiberglass truck lid with spoiler $150.00
72 lb/hr Siemens low resistance Injectors 3145 $275.00
Auto Gage 8,000 tach w/shift lite like new $65.00
HR Motor Mounts 0101 3.8 block (pair of poly motor mounts) $175.00
1in Plenum Spacer intake $50.00
Aeromotive A1000 electric fuel pump (red) $150.00
Autronic fuel management system w/software $800.00
Rear stock upper and lower control arms $30.00
Stock front springs cut to drop 1in $ 20.00
Rear stock springs cut to drop 1 in $ 20.00
Complete stock rack and pinion with power steering pump $ 150.00
2 Stock front brakes and pads $40.00
2 Stock front rotors $50.00
MSD dis-4 Ignition Box w/buick interface harness $250.00
VDO boost gauge 2 1/16 30 Hg to 25 psi $25.00
VDO boost Gauge 2 1/16 30 psi $20.00
Front stock sway bar $20.00
Rear Stock sway bar $25.00
2 pod center concel w/ oil and water VDO gauges (grey) $45.00
Left and Right stock inter fender wells the one has a
cut around for the downpipe! $50.00
Stock heater core $ 25.00
Stock drive shaft $75.00
Located in Limerick Pa for pick up or you pay shipping!
