I don't even know where to start to explain this ... so I put the passenger fender on the car the door to fender gap is bigger than it should be and the fender is pushed all the way back as far as it goes, and where the fender meets core support. The fender is riding 3/4 of an inch high above the core support no clue or reason for that, so we put the driver fender on and that one fell right into place no issues, all that is completely unexplainable, so we put the fender to core support bolts in and crank them down drawing the fender down which slightly bowed the fender, so next we bolt the hood on and close it..great hood is perfect lines up with everything perfect. Except one issue...the hood hinge hits the tall 15mm bolt in the passenger corner that holds the fender on at the top. The only way to correct this is to pull the fender forward and then the hood hinge will not contact the bolt. But then this throws the door gap way way way off. Its almost like you have to see it to fully understand im fu**ing lost as can be..hopefully someone has an answer
