Front coil overs?
jehenke
Big block guys, which front coil overs are you guys running? I currently have QA1 adjustables with Moroso trick springs. The springs are awful on the street. I dont see a retro fit conversion. I was looking at the full QA1 coil over kits. Any other ideas? Thanks.
TRZ Motorsports is the only way to go. The way to do it right is to replace the control arms with tubular arms from TRZ so you get the correct height spring. The Qa1 spring has issues stacking the coils so the travel isn't ideal. The TRZ lower control arm is designed to fit the correct length spring.
Thanks Dusty. Im running the Gbody Parts tubular arms already. I'll look into the TRZ stuff.
