SignUp Now!It is. That's a result of the factory cam button being a solid piece of plastic. The fix is to get a roller cam button from a 95 buick park ave 3800.
If you're going to reuse that cover make sure it's not worn so bad there's a tit in the middle sticking up. If so, you'll need to knock it down flat for the roller button. The correct way to do it is with a milling machine.
Casting flash, sharp edges, undersized feed passages, greater than 90* turns, poor oil routing, etc...
When those covers were designed they were for a little low HP car that didn't make enough power to really stress the oil delivery mechanism. Our engines like to load the hell out of the rod bearings just off idle. If the pump waits to get on the clock, it's a recipe for disaster.
