Front End Torque Specs
jpratt
Where can I find the front end torque specs for:
Tie rod
ball joints upper and lower
brake caliper bracket
sway bar end links
sway bar clamps
upper control arm nuts
and anything else up front in the suspension area
I have the specs but don't have enough time to get them before work. A 3/8 impact outta be more than enough though.
FRONT SUSPENSION *whenever possible tighten suspension comonents loaded*
upper control arm pivot shaft to frame nuts 48
upper control arm pivot shaft to bushing nuts 85
upper balljoint stud to steering knuckle nut 52
lower balljoint stud to steering knuckle nut 70
lower control arm bushing to frqame bolt and nut 65
front shock absorbwer upper satud nut 100in lbs]
front shock absorber to lower control arm bolts20
front stabilizer bar link nut 156 in lbs
front stabilizer bar bracket to frame bolts 24
REAR SUSPENSION
control arm bolts and nuts up[per and lower 80
rear shock absorber to lower mount 65
rear shock absorber to upper mount 144 inlbs
rear stabilizer bar to lower control arm nut 37
steering
steering wheel to steering shaft nut 30
outer tie rod end to steering knuckle nut 30
inner tie rod end to intermediate rod nut 40
tie rod adjuster sleeve clamp nut 15
steering gear to frame bolts 80
pitman arm to steering gear shaft nut 185
idler arm to intermediate rod nut 40
idler arm to frame nuts 60
intermediate shaft pinch bolts upper 46 lower30
wheel lug nuts 80 steel 100 aluminum-just thought I'd throw that in there.
rear shock to upper mount 144 lbs? ...could that be a typo...those are like half inch bolt and nut:confused:
