Oct 24, 2003 #1 W WarpSpeed Fade to blurr Joined May 25, 2001 Messages 464 Is this an easy operation? That is, simply drop the trans(gently), remove TC, remove 6 front pump bolts, slide the pump out and replace the seal.? Any thing i should look for or be aware of? Thanks 86GN - - slight trans leak
Oct 25, 2003 #2 V Vendor Defendor Out the window Joined Nov 25, 2002 Messages 3,537 can you give me the part number for this? i need to get it too. thanks -Neil
Oct 26, 2003 #4 C chris718 Active Member Joined Dec 10, 2002 Messages 5,356 are we talking seal or o ring/
Oct 26, 2003 #5 V Vendor Defendor Out the window Joined Nov 25, 2002 Messages 3,537 i was talking seal... mine ripped when i pulled the pump...
