Okay guys - I feel pretty confident in my mechanical abilities, but this is really starting to get to me.
I bought a 1986 T-type with 90+k on it and decided it was time to do the Valve Springs, Timing Chain and while I was in there put a high volume pump in it.
Everything went smooth until I lowered the car and fired it up. Then the oil came pouring out - not a drip, a pint at a time! So I checked it out and it appeared to be the front seal. No biggie - I took it back apart and replaced the seal (2nd time) and guess what it leaks but not as bad - still enough to make the car undriveable. Third times a charm right? So I do it one last time - get it back together and 15sec after firing it up I have about 1 quart of valvoline on the concrete
. I can't get this thing right.
I am using Felpro part # TCS 45930 (kit) - I assume this is correct?
The Pump was set up with the 60psi spring and holds there @ cold idle.
I see no visual cracks in the front cover.....
The first time the seal looked good but there was melted rubber on the balancer. The 2nd time I lubed the balancer with grease and when I tore it apart the spring had came off. I have yet to tear it apart this time. I am tapping the seal in with a piece of PVC that fits the OD - I have done hundreds of seals this way and none have leak (or I should say this bad
Short of buying a new cover (which I may do) does anyone have any suggestions. I'm dying here I have my alky kit ready to install and want to try my new 9/11.
Jeremy
Jeremy
