QuickWrench
Don't Read This
- Jan 28, 2002
I'm putting together the chassis for my '87 Limited now, and I need to get the front springs in.
If I mount the rear suspension, body, engine/drivetrain, etc (everything but the front clip), will there be enough weight to compress the spring when I use a jack under the front control arm?
I've had spring compressors break in the past, so I'd rather not use one if I don't have to. I can't believe the spring pressure in these things. I swear, I'm going to come up with a bolt-in strut for these cars.
'later...thanks.
'later...thanks.
