Turbo6Smackdown
- Dec 31, 2005
My front sway bar on my gn (stock) broke free of the passenger side mounting bracket. So, in replacing it, I thought I'd go to a larger bar as well. (1 & 3/8ths dia)
I did so, using energy suspensions mounting brackets, and end links. (the gold brackets with the red bushings you so often see) and after say, 200 miles, the same passenger side bracket, broke at the exact same spot again. (at the bend) The CS guy on the phone from ES says it may be, that my end link spacers were the wrong length, making the sway bar not parallel to my lower control arm, putting it at an improper angle. I checked it, and it was indeed correct. According to their diagram on their website http://www.energysuspension.com/pages/endl.html, mine is squared away. I guess mine is the 3 & 3/8ths long version. Any of you have this problem, and if you never did, what length are you little end link spacers? Anyone? This has been plaguing me for some time....
