ADDED & UPDATED PARTS: Deka 225lb. Injectors, BOP TH400, TCI Converter, BAER front Brakes, 8.5” GN Rear End, GBody Fuel Tank
BUICKTIME
It's ah me, Mario!
TurboBuick.Com Supporter!
Deka 225lb. Injectors, BOP TH400, TCI Converter, BAER front Brakes, 8.5” GN Rear End, GBody Fuel Tank _$1
Most Parts have less than 2k miles and are in great shape. Selling everything because I am going a different route. I have plenty pictures, just ask.
▶8.5” Grand National Rear End- 33 Spline Moser Spool and Richmond Gears_$2,200
Rear End is in excellent shape, practically new with approximately 2k miles. No issues, just upgrading. Everything has been replaced: Moser 33 spline spool, Moser Axles with c-clip eliminators, Richmond Gears (3.42), Aluminum LPW cover, 3” Long Studs, Brakes, Drums & Brake hardware._$2,200
▶Baer Brakes 11" SS4+ Front Brake Kit, Fire Red, Slotted, Drilled & Zinc Plated with spindles (Part #4301438FR). Complete with Spindles, braided lines and Fire Red ($350) Option. Paid nearly $2,500 asking _$1,800
▶BOP TH400 Transmission- 34 element sprag and direct drum, TCI Full Manual RVB & Transbrake, no waiting and no core (literally just got it back from being freshened up by Freddy Brown)_$3,200
▶TCI 8” Converter (Not pictured- $1,500 converter- *needs rebuild)_$400
▶Siemens Deka 225 lbs Injectors Low Z (set of 8)- (Best injector money can buy)- (AKA: SD220’s- Precision Turbo PFU041-2250 with approximately 500 miles)_$2,000
▶Dorman Gas Tank (*& Dorman 577-007 Fuel Filler Neck included) (not pictured but all Brand New)_$170
Listening to offers, but I will not entertain lowballers, PERIOD! I will ship on your dime. Preferred Pickup is in Nassau County, Long Island, NY.
_SOLD_ SPOHN Pro-Series Rear Anti-Roll Drag Sway Bar (Red) for 8.5" 10 Bolt GN/OLDS Rear End: part# (920-300R) paid about $500 selling for_SOLD_
_SOLD_
SPOHN_ RRx Series 1-3/8" Diameter Tubular 4130 Chrome Moly Front Sway Bar with Spherical End Links part# (925GT-Front-SEL)_SOLD_
_SOLD_
SPOHN (not pictured)_ Center link, Tie Rod inner & Outer ends- Front End Rebuild Kit part# (E-FRTKIT-G) paid nearly $400 selling for_SOLD_ _SOLD_ QA1 Rear Coil Over Kit- 18 Way Single Adjustable Shocks- Spring Rate 150# part# (736-G-QSA-14-150) paid nearly $900_SOLD_
_SOLD_
QA1 Front Pro-Coil System (not pictured)_ 18 Way Single Adjustable- (SKU# Q-GMP-G) paid about $800_SOLD_
_SOLD_
Selling as a set of 4 (F&R), includes the bottom mount to rear end (has a little rust on the springs that can easily be cleaned up_SOLD_
_SOLD_
BRAND NEW: GBody parts- Grand National Aluminum Wheels Rims- Full Set 15" x 7" and 15" x 8" _SOLD_
_SOLD_
BRAND NEW: Cardone Aluminum rear Brake Drums (probably the last new set you’ll come across, rare as hen’s teeth) _SOLD_
more pics
Dang, wish I would have seen those brake drums earlier...
Yeah, they sold pretty quick. Hardly ever seen them up for sale in last 5 to 6 years
MORE PICS
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (1).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (1).png
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (2).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (2.1).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (3).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (4).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (5).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (6).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (7).jpg
  • GBody Suspension Parts- Spohn Sway Bar, front end kit and QA1 Coilovers (8).jpg
UPDATED
