Front swaybar?
"Reaper"
Gone To The Dark Side
just went to the junk yard and got a 34mm or 36mm front swaybar.How do I tell witch one it is?Also where can I get poly bushing for it with new long side bolts and washers?
Shaun
You can get new bolts for the knuckles from gbodyparts.com and you can get the bushings and sway bar endlinks from rockauto.com
ok I haven't taken off my stock swaybar yet but its is big as well.If its stock is it solid and thats the reason for going to a different one?How big does the stock one measure?
thanks
The stock one is solid so it's 8lbs heavier than the hollow bar. The stock one I believe off the top of my head is 1 1/8"
