SignUp Now!When you made this adjustment,it moved the toe angle in an outward direction. It's the changing of the toe angle that helped your problem.So i changed the camber cause i was getting outer tire wear on the outer right side front tire put. The biggekitshim thay came with yhe shim kit think it was a 1/16 shim.fix the tire hop thanks guys .
