I just redid my oil catch can set up and replaced the 3.5" MAF-to-Turbo set up with a 4" tube that had a AN nipple for filtered air intake back into the engine. So, I thought someone could use the set up I took off. I was running the 3.5" Z06 Delphi MAF, and have a 4" inlet turbo, all with a PTE SLIC and up-pipe. The parts I'm offering are a nice thick 3.5" ID black rubber elbow to connect the MAF to the aluminum tube, a refinished 3.5" ID X 9" long satin black aluminum tube, and then a thick dark gray 3.5"-to-4" silicone elbow to connect to the turbo inlet. You will need to provide your own hose clamps. The metal tube was originally powder coated, but it had a couple of minor rub spots on one side from the rad hose hold-up bracket, so I filled them in with JB Weld, sanded it all smooth, primed it, and coated it with several coats of satin black enamel. All parts are clean and in good condition with no tears or dents. Asking $80 OBO shipped to your door in the lower 48 United States for the three parts. Also, I have 10" left of the 4" OD polished aluminum tube that I used for my new set-up. Asking $40 OBO shipped in the lower 48 for that, and I can post additional pics of it if requested. I left the yellow masking tape on it from when I cut it in my band saw. I can also shorten it a bit if you know how long you need. DM me for questions or to claim this stuff. Thanks for looking!
John A, Turbohh
John A, Turbohh
