diamond 8:1 forged pistons w/ rings and pins
L67 rods
stock crank
custom comp cam 218/214 547/506 115/115 (intake/exhaust)
!balancer (drilled and tapped)
roll master double timing chain (no dampner)
50% balance
04 gt H balancer
cnc lathed m90 housing for turbo blow through (and m90 cap off) (housing can be taken out of deal)
ported and polished lower intake (gasket matched to heads)
ported and polished heads (gasket matched runners, hogged, 1.9 manley severe duty intake valves, 1.57 manely severe duty exhaust valves (intense sells these), 130#s, new valve locks/seals.) if youd like further info on these i can get you in touch with the heads guy that did them)
mls 3layer head gaskets
arp head studs
intense OR rods
stock rockers
viton hydraulic lifters oe spec
stock water pump
intense oil pressure kit
i have a full build sheet for this motor. i can also put you in contact with the machinist who built this beast.
also have pictures of it all painted up.
3500 shipped
or PM offers.
L67 rods
stock crank
50% balance
04 gt H balancer
arp head studs
intense OR rods
stock rockers
stock water pump
3500 shipped
or PM offers.
