Ws6Stealthbird
- May 27, 2010
For sale: 82-92 Camaro and Firebird Spohn fully adjustable torque arm, with crossmember for a 700r4/th350, driveshaft loop welded factory from Spohn.
The spohn torque arm is fully adjustable to set your pinion angle within seconds. The torque arm is also mounted to the crossmember, not the transmission relieving the stress off of the tailshaft of the transmission. This crossmember is a must if you are swapping in a TH350 or another transmission that does not have a torque arm provision.
This item is used, but in great shape, ready to install. Bushings are greaseable, and are in great shape.
$325 shipped in the lower 48.
